How to Manually program the AT&T Universal Remote Control to your
TV here are the steps.
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink
twice then enter the code
922. The ATT button will blink
Thrice. If not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is
25. Dont worry its the volume of the receiver
To Program Your TV:*
Press the TV button and the OK button at the same time for 2-3 sec.
release them at the same time. The TV button will blink twice then enter
the code. Click
Here to see the manufacturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note:
After you program the tv make sure to press the ATT button. then now
check all the function of the remote. Follow the instruction and it will
work. If you press the power button the TV and ATT Recievier will turn
on and off at the same time
