Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My external hard drive appears to have a virus and now I can not delete the files off the hard drive. How can I reformat so I can eliminate the virus and clear the hard drive of all the files. I have already copied my files so I just want a clean reformat
Anonymous
Level 2:
  • Expert 258 Answers
  • Posted on Apr 03, 2010
Anonymous
Expert
Level 2:
Answers
258
Questions
Helped
67344
Points
737
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Right-click the drive you want to format, and select 'Format'.
1helpful
Delete folder
Is the folder write protected ? If yes then unprotect it and try again.
Are there other files on the drive that you can delete ?
You can always reformat the drive and clean it that way but you will need to copy the other files from it before you want to do that.
tip
How to download torrents or files SAFLEY
Many torrents or files downloaded from Lime wire, Bit torrent, and other torrent programs have viruses on them. There is a way to combat this so that these viruses cannot harm your computer. All you need is a flash drive or external hard drive. When you decide to download a file or torrent download on to the drive rather than your pc. Once it has been downloaded use a anti-virus program to scan the file. If the file is corrupt with a virus you can safely delete it. Should you open the file without scanning it and it does contain a virus don't worry there is still hope. Since the file is saved on a external drive or flash drive just reformat the drive and your computer will still be safe.
on Jun 27, 2010 • Computers & Internet
The files in my 500gb hard **** turn to short cut
scan your usb because your files has infected with viruses, go to start in your PC look for cmd command type cmd you will drive D: change to your drive just type E: or F: and type dir to see all files. or reformat to remove virus save your files to other drive.
I CANNOT LOG ON TO MY 500GB IOMEGA EXTERNAL HARD DRIVE
can you see the External HD on the My Computer? and when you right click to open or double click won't open? but if you can open the external HD using the drop down tool at the my computer, then the problem is virus. You should update your anti-virus then scan it to delete those virus, and if you do not have any important files, i guess its much better to reformat the drive.
please let me know your further query.
regards,
toeped
I can't copy files from my Seagate External Hard Drive. The light is blinking but I can't open the hard drive from my computer. Earlier I was able to see the files but I can't copy them to a new hard...
Click "Safely Remove Hardware" in your tooltray (one of those little icons on the lower right
of your screen across from the START button - its a green arrow over a PC board). That'll
remove it from the system, then re-attach it (Windows Plug-n-Play will find it and re-mount
the drive).
Then, deep-scan your anti-virus software on your entire system - the possible cause of loss
of directory structure on your external HDD.
Then, run CHKDSK on your Seagate External Hard drive - to make the directory structure sane again.
How-to-do-this: START> Run > (type in) chkdsk
Then, download (free) "Recuva" software from http://www.piriform.com to recover anything lost in
making your external HDD's directory/file structure sane again.
Run Recuva in this mode:
Recuva > Options (button) > Actions (tab) > Scan for non-deleted files (for recovery from damaged or
reformatted disks)
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Stop 0x00000024 (0x00190203, 0x82F8FA28, 0x0000102, 0x 00000000) appears on my screen. Blue background. What can I do to repair this?
Your system has suffered an unrecoverable error. Either vital operating system files have been corrupted, deleted or overwritten or your hard drive has failed. I suggest reformatting the drive and reloading the operating system from scratch. This can also be cause by some virus infections currently in the wild ( viruses that are currently circulating the internet) so make sure you boot from a system disk and reformat the drive or drives from this boot disk. Sorry but you have very few chances of a successful recovery from this without reinstalling your operating system.
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
2helpful
4answers
Removal of boot.com virus from external hard drive and USB Stick
Silakan baca di >sini<
Desi Vibes
"boot.com" is a virus which attacks the hard drives & the hard drives could not be opened by double clicking. In hard drives after enabling viewing hidden file u can see some "autorun" file & a file named "boot.com" which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
5answers
My precious files...
If you have not written anything to the disk since you accidentally formatted it I can recover all your files for you. If you wrote any files to it some of the files will be ruined. I have FBI forensic software that can do what you need and more. Rate this fixya and post an e-mail address and I will get the software to you.
George
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
