20 Most Recent
SmartDisk FireLite - 80GB - 5400rpm - USB 2.0 - USB - External 80 GB Hard Drive Questions & Answers
The drive suddenly stopped being detected by my
here is a general look at
the drivers and how to update them
if your computer came with
a motherboard disc the drivers could be on it
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
make sure the lead/s that
attach to this drive have a secure seating and are not bad/faulty the light on
only tells that its getting power it might not be getting enough power you
might test the lead/s or
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again, sometimes the wires inside the cable will be damaged due to bending
or stretching or placing heavy equipment upon the cable,
check the USB leads that
attach to the motherboard usually red-white-green-black make sure they are
securely seated and have no dust build up on them dust will cause static and a
lot of unforeseen problems
hope this helps
4/28/2011 12:39:59 AM •
SmartDisk...
Answered
on Apr 28, 2011
On my smartdisk firelite the conection that
you can open the case and remove the hard drive and install it in a new external usb case for it.
you can find out what type of case you need after you open it. it could be either a SATA connection or IDE.
If it is a SATA and you got a SATA cable/power you could also just install it directly into your computer and grab the files you need.
3/11/2011 5:54:49 AM •
SmartDisk...
Answered
on Mar 11, 2011
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
10/8/2009 5:07:24 PM •
SmartDisk...
Answered
on Oct 08, 2009
My computer recognizes this hard drive, but windows media player does not
With Windows Media Player open, hit the F3 key. You get an Add To Library window providing you with an option to sync folders from other sources...like an external hard drive.
Select the option to add My folders and those of others I can access. Then you click the Add button.
Now you can see the Add Folder window. Search for the folder where you stored your music on the external hard drive and select it. Then click the OK button.
This will add the selected folder on the external hard drive to the list of synced folders. Once the Add Folder window disappears, Windows Media Player starts syncing the music and adding it to it's library.
9/8/2015 4:52:45 AM •
SmartDisk...
Answered
on Sep 08, 2015
I plugged in and powered on the SmartDisk CrossFire XF160 to my windows 8.1 pc, it automatically installed driver, but the drive does not appear in windows explorer. what can i do?
NO story told , first time used, this??? just bought it?
is it new or used,? IDK any of that, and data matters.
Ill assUme it is new with no precious data....
no PC stated, , w8.1 why not upgrade for free to w10?
smart disk or any external HDD, or SSD, all need to be formatted
first. you did only the last step. (first)
#1 plug in the USB cable to a working USB port.
2: go to CP control panel then admin tools then computer management and last disk management or.
2b: in the run box type
diskmgmt.msc
3: now diskmanagment is OPEN.
4: the drive shows up as a DISK NUMBER. only
5: right click your DISK seen in the list, do not pick Disk 0
6: make sure the DISK U picked size matches your external disk size.~~
7: right click the DISK1 or what it is and pick new simple volume
8: right click disk1 and format it. to fat 32 or NTFS.
9: assign a drive letter to the new drive, (from now on the drive external shows up in windows explorer as drive letter same.
that is it, same story on new empty USB thumb drive !
12/19/2019 1:40:12 PM •
SmartDisk...
Answered
on Dec 19, 2019
