Receiver will not recognize HDMI input for sony blue ray dvd player. I have had reciver for about 14 months. Now all of a sudden we can get sound but no video or nothing at all. We get ATT U Verse through the receiver fine. We believe it's the receiver rather than a TV problem because the receiver will not show HDMI on it's display screen. When it does, the dvd can be seen and heard.
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Search "how to fix an onkyo tx-sr606" on youtube. It will show you how to fix it.
I thought my Panasonic BD 35 was the issue... after 10 to 30 minutes of not having a picture on the screen w/ sound is coming from my speakers... I could take the hdmi input from back of receiver and plug into my tv and get a picture... I got an email response from Onkyo support. They instructed me to reset it back to factory settings... Press and hold the Clear? and then power down. Let go of the buttons... power on! If this doesn't work pull out your receipt and they will give you instructions on where to take it for warranty work... if your still with in the two year window. Good luck.
Dunnbiker... do you read other forums? this issue is pretty well documented... more than one source and it's considered common knowledge... Google search it.
Why can't it be the BluRay player or its cable?
BTW: is the BluRay (model X?) the new kid on the block? It probably has a number of settings that could be causing the problem.
Have you proven the Blu-Ray and the ATT act the same on any HDMI input; or that only one HDMI input is squirrely?
Try a differnt HDMI input on the Onkyo and/or the component video connections from the BluRay. I use HDMI/DVI and component to my TV because it only has the one DVI and I can't see a difference in HD content.
I have the exact same problem with my Onkyo Sr606 receiver -I have a Sony S306 blue ray player connected with HDMI to input 1 of receiver ( DVR input ) Had receiver for about 15 months now - Everything was working fine until about 2 weeks ago , I put in a blue ray movie & got nothing on screen -- tried connecting blue ray to all 4 HDMI ports nothing - My TV also takes a bout 5 -- 10 minutes sometimes before I get a picture . connect player direct to TV in living room & bedroom -- no problems I get a picture within 5 secs. of turning on player.
MY 806 has a delayed start on audio then eventually video. This is frustrating, I can't see myself throwing away the $800 I paid for the receiver. Does anyone know the real cost for the HDMI Board? Is it a DIY project or does it require a professional?
