To set the time and date on your Timex Indiglo watch with a CR2016 battery, follow these steps:
Press and hold the stem (the button on the side of the watch) until the display begins to flash.
Use the stem to cycle through the different settings: time, day, date, and year.
When you reach the setting you want to change, use the stem to adjust the value.
Once you have set the time, day, date, and year to the correct values, press the stem to exit the setting mode.
If you have trouble setting the time and date on your watch, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Timex customer service for assistance.
The watch should have only one stem on the side, if this is so, you pull the stem all the way out two clicks to set time, but you pull it out only one click to set day and date, at one click you turn one way for date and other way for date, to use indiglo you push stem in. If your watch has more than one stem please notify me. I hope this helps!
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
