DELL Inspiron 910 Netbook 9'' monitor LOSES (dims) when power plug is inserted...It's much brighter without the plug...What can I do?
Hi there!
Try to change the setting of the brightness in BIOS,
You can access bios by pressing f2 after you turn on the computer, then you will see brightness there, max out the brightness.
If it still does not work then go to the power options of your laptop then change the setting of the brightness when the charger is plugged in.
Hope this helps!
