20 Most Recent
Dell Inspiron mini 9 - Black , Intel® Atom Processor® N270 1.6 Ghz , 1 GB DDR2 at 533MHz, 8GB Soli... PC Notebook Questions & Answers
How do you do a password reset
you must open the laptop and take the small battery for 1.5vdc inside . and the short circuit the 2 wires , and then proceed and reverse sense.However you must go to the control panel, and go user account and reenter the new password. more easy. or go to the BIOS in restart with the key esc or f2 depend of you model and go the BIOS setupGod bless you
Dell mini 9 problems
Sir, kindly Do windows on it .....You will soon get an operating system :)Thanks
Dell Mini 910 Laptop: Removed
Hi!
As described in the title, your DELL Mini has a very small capacity SSD (8 GB Solid state drive).
For windows operating systems toghether with some usual applications like MS Office, messengers, adobe reader and flash player etc. it is simply not enough.
Of course, installing a larger SSD instead of your 8GB one will solve the issue, but I think it's not what you expect for an answer.
That's why I try to suggest an alternative way:
Please go to CONTROL PANNEL, ADD AND REMOVE PROGRAMS (in WIndows XP, in Windows 7 it is called PROGRAMS AND FEATURES).
In the displayed list please uninstall any programs you do not really need. Also, in the left side pannel there is an option called add/remove windows components: here you can uninstall other applications e.g the games contained in the windows installation like solitaire.
After doing so, you will gain some free space on your SSD.
Please let me know if it worked,
How to reinstall <windows
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
1.Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2.Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3.In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4.Select the operating system you wish to fix, and then enter the administrator password.
5.Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6.You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7.Type exit to reboot the computer.
Free Driver
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
My inspiron 910 has SSD
1. To access boot options on this netbook press 0 on startup. This gives options to start from usb drive or external cd.
2. If you have an external cdrom, then use this with any xp home cd to attempt repair/ repair installation/ re-installation.
3. unetbootin allows you to create a bootable usb from a cd image (or you could use it to make yourself a linux netbook).
How can I find my license key for my Dell Inspiron
windows license keys are usually in a manual for OEM products OR you could download magical jelly bean keyfinder (link : http://pcsupport.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=pcsupport&cdn=compute&tm=43&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=4&bt=0&bts=1&zu=http%3A//magicaljellybean.com/keyfinder/) install it and it will find all the license keys on your pc!
A/c adapter will not charge battery. Got a new
you got new a/c adapter or new battery? If you got new a/c adapter then you need to replace the battery... thats what it sounds like:)
Batteries wear out over time and usage. To get the best use out of your battery try to always charge when little power is left:) Thnx
I have a Dell Mini 9
Hold down the Ctrl key and tap the - key, that will reduce the size of the web content.
Booting issues
Mini's doesn't come with an optical drive. Better go to a local technician to have your hard drive pulled out and important files extracted and saved on an external drive.
When the hard drive is installed back in your laptop, you may reinstall factory image by pressing or tapping F8 on the Dell logo.
- Select "Repair your computer" and press Enter.
- Click Next when you're in a page asking for the keyboard language options.
- Type your password when prompted.
- select Image Restore and click continue.
Your system will reinstall a new copy of the operating system it came pre-installed together with all the software included when you first got your machine.
Hope this helped... ^_^
Hello i have a dell mini 910 and it has no space
using an external HDD doesn't require dual booting.
First connect the external drive, and copy files to the drive that don't require and applications to be installed (MP3s, Avi Videos, Pictures)
Then you can delete the files from the HDD, this will immediately give a boost in performance. Generally, most games run a an Atom powered system don't take a great deal of space, so moving applications to the external drive likely would not be gratly beneficial as keeping data files there.
Dual booting by the way, is the process of installing 2 operating systems on a computer and being able to boot to more than one version. (Windows XP and Vista for example) of Windows and another OS (XP and Linux)
Dell mini
you just stated "dell mini". What really is the problem with your dell.
I look forward to your reply.
Good luck.
