First figure out what output video the computer has. These days it can be VGA, DVI, or HDMI. Then determine what video inputs are on the monitor (same list). Then plug in the desired cable. Many monitors only come with the VGA cable. If you do not have a VGA port on the computer you would need a DVI to VGA adapter to use that cable. Otherwise buy the DVI or HDMI cable. (DVI to HDMI cables exist if you have HDMI but no DVI on the monitor and only DVI on the computer. However, you need to check your video specs closely. A Single link DVI is different than Dual-link DVI and the cables are not interchangeable.)
Once the data and power cords are plugged in, power up the monitor and then the computer. The computer should find the new hardware and install (or ask for a disc to install) the drivers.
I hope this helps.
