SOURCE: front turn signal bublb replacement
The only real way to do this is to remove the headlight assembly. There are two T30 Torx bolts on the top brackets for the headlight - remove those. The third bolt is harder to see. In the top of the fender, down over the headlight, there is a round hole. Shine a flashlight down there and you'll see the third Torx bolt. Unscrew that and then use one of those $1 magnetic retrieval tools they sell at the parts store to pull the bolt out.
Once these three bolts are out, you can manipulate the headlight out of the front of the car. From that point it's easy to replace the bulb. Reassembly is the reverse of removal.
SOURCE: Remove and clean Toyota Echo heater fan.
The fan is under the pass dash, remove the glove box and you should see it, 1 plug and 3 8 mm screws.
Testimonial: "Thank you very much."
SOURCE: How do I change the headlight bulb?
rubber gasket can be peeled back to expose conector.
Testimonial: "Thanks so much. The advice worked perfectly. "
SOURCE: How do I change the headlight on 00 toyota echo?
You gotta twist the whole thing, before you take off the wires from the back of the bulb about 45 degrees, then pull straight out. It's not "screwed in" like a light bulb in your house. I just changed mine, and had to figure it out. Took me a minute, but I got it. It's a small space in there. Good luck!
