SOURCE: The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
SOURCE: horrible noise and burning smell when dryer is on
Same thing happened to us, the noise is one of your wheel bearings are going bad, (they are just a small piece of plastic rollers) and the smell is your belt. The dryer is dismantled from the front. I figured out how to take my dryer apart from google. Also, you may need some help to pull out the drum wheel and pay attention to how it came out. I ordered parts from repairclinic.com and it was very inexpensive and the parts took 3 days to come to me ( I wouldn't pay for faster shipping).
Good luck, you won't believe how uncomplex your dryer really is.
same problem here also
