MY DELL LATITUDE E6400 HAS THE PRESENTATION MODE SET TO LCD ENABLED AS DEFAULT WITH FULL PRESENTATION MODE DISABLED HOW DO ENABLE FULL PRESENTATION MODE, DELL QUICKSET IS NOT INSTALLLED AND THERE IS NO DELL QUICKSET PROGRAM FOR THE LATITUDE E6400 ON THE DELL WEBSITE THAT I CAN FIND
You may want to follow the below steps to disable Microphone:
(1)Right click on the speaker icon in the status bar.
(2)Select Recording device.
(3)Right click on Microphone array and disable it.
However, if you want to enable this later on you may just right click on the same screen and select show disabled device. Right click on the device and enable it.
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
You should see a screen icon on the keyboard, (usually its the F6 or F8 key). Press FN and that key, and that should switch from LCD to External, then to Dual, then back to LCD.
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
ok
start menu -> control panel -> power options -> under power schemes click the drop down arrow and "Presentation" mode is near the middle
click "OK" and your set to go
hope this helps
toggle between screen display modes by holding function and f8 together- there may be a few seconds delay between each settings so be patient
if that fails , then goto display settings and in advanced you should be able to select the displays you want.
