Manually turn on the device (TV, VCR, etc.) to be controlled.
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Ok there's a lot!
1005, 1021, 1043, 1085, 1160, 1161, 1210, 1218, 1219, 1242, 1248.
Please bear in mind some codes will operate some functions but not all, you might need to check different operations before you get the right one.
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
I wish you luck on your search for an answer, but vcr's are programmed for a possible life expectancy. So ur vcr was expecting to be in a landfill by january 2009 and according to its programming there is not a 2009. Combo units at walmart are realativly cheap now a days I would recommend picking up a new one.
