Hardware & Accessories Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I INSTALL A TORK SS720A TO A THREE WAY SWITCH
Anonymous
Level 3:
  • Master 565 Answers
  • Posted on Mar 07, 2010
Anonymous
Master
Level 3:
Answers
565
Questions
0
Helped
269939
Points
1490
The Tork SS720A's can only be used to replace a single pole switch. For 3-way switches you need the Tork SS700 or similar device like any of the SS700Z series.
http://www.electriciansupplies.com/product.cfm/p/123028/Tork-SS700.htm
1 Related Answer
A
Anonymous
  • Posted on Nov 09, 2010
SOURCE: I need a programing book
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
TORK 1101 24-Hour Indoor Mechanical Time Switch 40A. A spring broke on the OFF switch and I'm unable to locate a diagram showing the spring connections.
The is nothing online. Ask NSI Industries if they can service it? You may even get a warranty repair if a spring boke.
TORK 1101B 24-Hour Indoor Mechanical Time Switch 40A ...
NSI Industries https://www.nsiindustries.com > product > tork-1101b...
TORK 1101B 24-Hour Indoor Mechanical Time Switch 40A 120V, SPST Outputs ; Repairable Units · Mechanical time switches can be repaired when components reach the ...
https://www.google.com/search?q=Tork+1101+parts+diagram
We are Fixya, not Tork, we just have a category for it.
Tork RZ307 Automatic Lighting Timer . . .
Edited 'Trok' to 'Tork'.
Then with the right maker, we can find the Tork Timer Category.
Also added (what it is).
It is new, it is under warranty, take it back for free replacement. If you fiddle with it, you void that warranty/ The only thing you can try is cutting the power at the breaker for 5 minutes. If that doesn't work, disconnect it for 3 days as it has a 2 day backup. See if there is a battery compartment with a dead bulging capacitor in it.
Power Outage Backup:
Permanent schedule retention with memory module.
Supercapacitor provides 2 days of real time backup.
http://www.nsiindustries.com/catalog/nsiproducts/tork/tork-digital-time-switches/in-wall-and-plug-in-timers/rz307
https://www.google.com/search?q=Tork+RZ307
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Lost programming instructions, need help to reset or copy of programming manuel
Go to tork.com/tork/residentialtimers.aspx and you will see your model and then click on it for your wiring diagram
I just took over an old building with three Tork Digital Timer Switched EW 120A-C. I have no idea how to reprogram these to get them to do what I want. If the overhead lights are on, no outlets work and...
Here's a link to the Tork website. The model timer you have is a past model. The manuals are listed in the technical library.
The model you have is most likely either EW101A SERIES or EW101SA SERIES
See the library for details: http://tork.com/techlib.aspx
Top TORK Hardware & Accessories Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
