Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
Posted on Mar 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune with antenna, 50.1 came back only once then reverted to 51.3 after changing channel. No such broadcast channel 51.3 in Chicago nor is it listed in tuned channels menu slots. Now 38.1 (ION) is ocassionally showing spanish shows and english channel gone time to time. Turn off tv for a while and 38.1 comes back. All other channels normal.Other tv in house 50.1 and 38.1 channels normal same antenna. Two Panasonic DVR tuners channel 50.1 and 38.1 are ok. Same antenna. Thinking problem is getting worse. Any ideas??
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Mar 27, 2017
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008706
Points
237762
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5 Related Answers
fred2222
  • Posted on Apr 30, 2008
SOURCE: When in Antenna mode (DTV from the Aerial) some channels do not tune in....
I found I needed at least 80 percent.
Anonymous
  • 10594 Answers
  • Posted on Apr 14, 2009
SOURCE: Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 10, 2010
SOURCE: I need lcd screen
Try contacting www.shopjimmy.com
It is not going to be cheap if you can get one, it will be more than the TV is worth.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
gopakumarg43
  • 76851 Answers
  • Posted on Feb 23, 2011
SOURCE: How to tune channels first
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Mar 22, 2011
SOURCE: I have lost channel 09
try autoprogramming at different times. signal may be better during the day than at night, and vice-versa.
No sound on any channel
Are you on mute by accident? If not your sound circuit needs repair.
Or the power supply line power distribuition.Some voltage is missing
to the sound circuit.
3helpful
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Screen went black and the menu will not show. still have audio
If you get no picture at all, not light is visible on the screen, it may means that the backlight inverter board has gone out, or the power supply that supply the voltage to the inverter board has gone out. Use a flash light flush on the screen to see if you can see any thing at all.
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Doesn;t show itv 1 or channel 4
edit your inputs and make sure itv1 has't been put on skip
your channel 4 could have been automatically deleted if you did an auto program on the channels.
Poke around in the menu and you should be able to tell it to display channel 4
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
