20 Most Recent
Sony BRAVIA KDL-32S2010 32 in. LCD Television Questions & Answers
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR)
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
No audio on my sony tv flat screen
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output.
If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
No sound
Are you on mute by accident? If not your sound circuit needs repair.Or the power supply line power distribuition.Some voltage is missingto the sound circuit.
Ps3 doesnt give out a surround sound output
Hi In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option. If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver. After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.Aslo the following setting in PS3 Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..=
DIGITAL OUTPUT (OPTICAL)Ajin
The screen turns off but
Hello dcbio77,
Welcome and thank you for using FixYa!
Your tuner board is the issue here. It can be checked for bad soldier joints, or replaced.
Have a great evening!
I have lost channel 09
try autoprogramming at different times. signal may be better during the day than at night, and vice-versa.
Kdl-32s2010 .... after 1 hour,
The sattelite box have issues,tries unplug,replug the box back like about an hour later for it to reboot and resetting and upgrading it softwares.This tv problems switching modes to digital and to analog again back and forth should be solved.Still happening the box have problems,call ur sattelite provider change the reciever box.
For no reason it turns
Let me know how many times its light flashing after 3 seconds pause, this is an error code that has info about defective section of tv, it will help me to diagnose problem and to suggest solution.
Just to confirm, is it Sony KDL-32S2010 lcd tv as mentioned in question headings or any other model.
Thanks
Screen went black and the menu will not show.
If you get no picture at all, not light is visible on the screen, it may means that the backlight inverter board has gone out, or the power supply that supply the voltage to the inverter board has gone out. Use a flash light flush on the screen to see if you can see any thing at all.
