Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
Posted on Mar 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set current time and date? - Samsung Tocco F480 - Pay Monthly Cellular Phone
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 138 Answers
  • Posted on Mar 01, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
138
Questions
0
Helped
39980
Points
402
You can find it in the manual use these links
http://www.samsungmobile.co.uk/support/softwaremanuals/software.do?phone_model=SGH-F480&sw_type=UM
or
http://cellphone.manualsonline.com/manuals/mfg/samsung/f480_pay.html
How to set the time on a nuband
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
https://watchonlineclub.com/bodyguard-2011-hindi-bollywood-full-movie-watch-online.html
How to set time on nuband
2. SETTING THE YEAR
year.
NOTES:
4. SETTING THE DAY
day.
5. SETTING THE HOUR
NOTE:
Zindagi Na Milegi Dobara 2011 Hindi Bollywood Full Movie Watch Online
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
2. SETTING THE YEAR
year.
NOTES:
4. SETTING THE DAY
day.
5. SETTING THE HOUR
NOTE:
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
How to set date and time on canon mp25dv calculator
How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator
The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work.
The correct steps for setting the time and date on this calculator are listed below:
1. Press the time/calendar button one to select the date mode. The display should show the month-day-year.
2. Hold down the = button until the month start flashing.
3. Use the number keys to enter the current date, month and year. Example 07-22-2021
4. Press the = key to set the current date.
5. Press the CE/C key to return back to the calculator mode.
6. Press the time/calendar button twice to select the time mode. The display show the
hour-minute-seconds & time of day. Example 02-01-14 A
7. Hold down the = button until the hour start flashing.
8. Use the number keys to enter the current time.
9. Press the X button for (A) a.m. or (P) for p.m.
10. Press the = key to set the current time.
11. Press the CE/C key to return back to the calculator mode.
12. To check the current date and time on your calculator, press the calendar/time button once
for date and twice for time.
1helpful
How do I set date and time?
  1. To set the current date and time, press and hold down the SET/EDIT button for 2 seconds, let go and the Month (M) and Day (D) indicators will start flashing.
  2. While the Month (M) and Date (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format, press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR and MINUTE fields. The field that is currently active will start flashing. To change a field's value press the LOCK button, each stroke of the Lock button moves one value up.
  4. Once you are finished setting the Date and Time press the SET/EDIT button to return to normal display.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189, and back up to the current year. Be cautious when setting the year
Resource 1: Dymo Date Mark Electronic Date/Time Stamper Manual
7helpful
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
127helpful
4answers
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
To set current time and date in my screen
hi
please tell which handset you are using?
generally you can do it by going to clock /options/settings/time
Hope this helps
May 25, 2009 • Cell Phones
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 • Cell Phones
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
