Google Gmail Logo
Posted on Mar 01, 2010
How to freeze my gmail account. that means i need my gmail id but some period i want to block incoming and outgoing mails without deleting gmail.
Ahmed
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Jul 23, 2010
Ahmed
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
8332
Points
52
I don't think it's possible to desactivate your gmail account temporary.
You still able to delete gmail from your google account services.
go to
https://www.google.com/accounts
scroll to "My products" than click on modify
you'll find an option to delete gmail definitely
  • Wendy Swetlishnoff
    Wendy Swetlishnoff Sep 01, 2014
    no I don't want to do that at all I need to find out where this account is from
Stripe The Gremlin
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 18, 2013
 Stripe The Gremlin
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
26591
Points
10
Here is how to delete your Google account including Gmail:
  1. Delete or restore a Google Account
It's somewhat temporary because you can attempt to restore it but "within a limited window of time after deletion". It's not specific enough in my opinion but hopefully this helps.
11helpful
4answers
How to configure my samsung gt c3303K phone to set up an existing email account
if you have gmail account set incoming server stmp.gmail.com and outgoing server pop.gmail.com
tip
Gmail on outlook!
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
Log in to your Gmail account.
At the top of any Gmail page, click Settings.
In the Mail Settings window, click Forwarding and POP.
I don't see Forwarding and POP
Gmail is turning on POP3 support for users in phases. If Forwarding and POP does not appear, your Gmail account cannot be configured for POP3
support.
In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
Click Save Settings.
In Outlook, on the Tools menu, click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click POP3, and then click Next.
Under User Information, do the following:
In the Your Name box, type your full name the way you want it to appear to other people.
In the E-mail Address box, type your e-mail user name followed by @gmail.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.gmail.com.
In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
Under Logon Information, do the following:
In the User Name box, type your full e-mail address, including @gmail.com.
In the Password box, type your password.
Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check
box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also
means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine upper- and lowercase letters,
numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Use a strong password
that you can remember so that you don't have to write it down.
Click More Settings.
On the General tab, under Mail Account, type Gmail.
Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
Select Use same settings as my incoming mail server.
Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server
requires an encrypted connection (SSL) check boxes.
Change the Outgoing server (SMTP) port number to 465.
The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL)
check box.
Click OK.
To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be
prompted to supply or correct it. Make sure your computer is connected to the Internet.
Click Next, and then click Finish.
Notes
Do not select the Log on using Secure Password Authentication (SPA) check box.
Unless specified by Gmail, all server and address entries are typed in lowercase letters.
This works for both Outlook 2003 and 2007!
2helpful
I own a samsung GT I 9000. Have been trying to synchronize with my corporate mail server without success in spite of following the screen tips. Could you please help me or atleast guide me to a custormer...
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format [email protected] [email protected]
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
I have a samsung b3310 on o2 and it wont let me send photos to my email address. I contacted o2 and they said they cant give me the settings because its pay as you go. I have never had this with any other...
It would help if you mentioned your provider, ie "live.co.uk" "gmail.com" etc. Enter everything as normal (email & password) & change these options. I know only these 3 so far, Hotmail, "***@live.co.uk" Account type -POP3-, Incoming -pop3.live.com-, Outgoing -smtp.live.com- Yahoo, "***@yahoo.com" Account type -IMAP4-, Incoming -imap.mail.yahoo.com-, Outgoing -smtp.mail.yahoo.com- GMail, "***@gmail.com" Account type -IMAP4-, Incoming _imap.gmail.com-, Outgoing -smtp.gmail.com These should be the only changes you need to make, always check the secure connection. If you still have problems setting up change your username to your full email address, you'll find it between your email and password. Hope this helps as it took me months to figure out the simple switch of "co.uk" to "com" or deleting the "4" from "imap4" in the incoming sever. Hope these tips help!
5helpful
9answers
I want incoming and outgoing call details of my cell number 9621010060. its a airtel network. its humble reuest please as soon as possible. my email i.d is [email protected]
my airtel prepaid no is 918894255042 Please send call detail incoming and outgoing last 3 months its humble request as soon as possible. my email I.D. is [email protected]
I want to send an email when a blue window pops up but dont know if my yahoo is pop3 or imap server? i also need incoming and outgoing e-mail server HELP
Incoming mail server settings
•POP server: plus.pop.mail.yahoo.com
•Use SSL
•Port: 995
Outgoing mail server (SMTP) settings
•SMTP server: plus.smtp.mail.yahoo.com
•Use SSL
•Port: 465
•Use authentication
•Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com", for example, “testing80”)
•Email Address: Your Yahoo! Mail address (for example, [email protected])
•Password: Your Yahoo! Mail password
Troubleshooting tips
If you still can’t send Yahoo! Mail from your mail program, you may be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try setting the SMTP port number to 587 when sending email via Yahoo!'s SMTP server.
Your email program gives you the option of either deleting your Yahoo! messages from the Yahoo! server after downloading them into your mail reader, or leaving them on the Yahoo! server so you can see them online in your Yahoo! account, too.
Jan 19, 2010 • Yahoo Mail
2answers
To E-Mail Document. How do I identify my Incoming Mail Server
contact your internet service provider and they will be able to help you i could probably tell you but i dont know your email address
2helpful
Email account setting
hi,
you have to select imap4 as the connection type, not pop3.
incoming mail server ---- imap.gmail.com
outgoing mail server----smtp.gmail.com
these are the setting that are needed to access gmail on your mobile
rate me if it solves your problem.
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
