Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Let's start again:
WHAT MODEL SUBWOOFER?
Specifically point-to-point where is it connected? Warning: one doesn't casually connect things to speaker connections.
If the Sub is self-powered (has RCA jack) it should have ONLY an RCA cable running from the Sub Out of the receiver connected to the RCA input on the sub, NO speaker cables.
For any modern AV Receiver you should try to understand how it works for maximum enjoyment of it. Speaker connection is fairly standardized, but set-up is unique to each maker and model. To define the speaker types and sizes and set the relative volumes you need to dive into the manual, available at retreveo.com for free after you register.
Once the sub is connected correctly you will have only bass going to it and the volume control will work for it.
yeah the sub works. at the moment its connected via speaker cable and i plugged some rca leads into it. but i dont ever remember having the rca leads plugged in the first time. also its acting a s speaker not a sub with the ports i have it plugged into.
all sorted it does need the rca leads i just dont ever remember having them. just gotta learn how to read properly haha it has specific rca outputs to go into and uses speaker cable for a high input. thank you for your help mate. hope to return the favour one day
