20 Most Recent Yamaha RX-V363 Receiver Questions & Answers
HELLO MY NAME IS ROBERT.
The TV may have HDMI ports, but the V363 may only have RCA outputs. Video Audio HDMI Male to 3 RCA AV Cable Adapter Audio Video Component DV Convert HDMI to 3-RCA TV Adaptor Line For HDTV 1080P AU https://www.aliexpress.com Try here.
2/17/2018 8:19:36 PM • Yamaha RX-V363... • Answered on Feb 17, 2018
I want to run a external amp through my yamaha natural sound receiver RX-V363 also have a graphic equalizer I would like to incorperate in the system
You can use the tape in/out connections and the pre amp connections on the back.
1/6/2017 2:14:10 AM • Yamaha RX-V363... • Answered on Jan 06, 2017
Hi, I'm looking for Panasonic LCD code, I have Yamaha RX-V363, plz share me a code.
Is that a code for the remote?
1/6/2017 2:06:21 AM • Yamaha RX-V363... • Answered on Jan 06, 2017
2answers
My comcast remote won't turn
It controls the volume just fine. It's the power that doesn't work. I'm having the same problem with my Yamaha receiver. Different model. Multiple Comcast remotes too.
3/30/2016 11:54:24 PM • Yamaha RX-V363... • Answered on Mar 30, 2016
System not working found transformer open where i will get the power transformer? what will be the rate
all the transformer details are stamped on the transformer find an electronic parts shop or a tv repair shop and see what you can get
2/22/2016 2:29:28 AM • Yamaha RX-V363... • Answered on Feb 22, 2016
Yamaha RX-663 Powers down
It sounds like it's going into safe mode try testing the resistors just after the power supply you will probably find one or two at fault
2/15/2014 10:44:59 PM • Yamaha RX-V363... • Answered on Feb 15, 2014
0answers
2answers
I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
6/24/2013 4:44:25 AM • Yamaha RX-V363... • Answered on Jun 24, 2013
Yamaha receiver silent cinema
are there headphones plugged in? Otherwise something is wrong with the headphone jack probably.
4/22/2013 12:50:49 PM • Yamaha RX-V363... • Answered on Apr 22, 2013
2answers
Connecting xbox 360 to RX-v365
have to change the hdmi mode for the tv, also co-inspone with the receiver
4/10/2013 3:20:58 PM • Yamaha RX-V363... • Answered on Apr 10, 2013
Can't get 5.1 out of my xbox 360 I have a yamaha rx-v365 and a vizio 1080p tv. just get 2 ch stereo
you have to go into your auido setting and manually change it
7/19/2012 3:41:16 PM • Yamaha RX-V363... • Answered on Jul 19, 2012
My yamaha receiver RX-V363 keeps shutting off and saying check SP cable
It is one ot two things, the audio output transistors or ic,s are shorted, or the speaker wires in the back of the surround sound are shorting.
4/9/2012 5:32:05 PM • Yamaha RX-V363... • Answered on Apr 09, 2012
Yamaha RX-V363 Receiver Logo
72 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
system not working found transformer
  • Audio Players & Recorders
