My sound will not work on dell d360 with XP. I get an error that says "the i/o operation has been aborted because of either a thread exit or an application request" and the driver will not load.
Open the Control panel
Open the "Sounds and Audio Devices" icon.
Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
If you were able to check this box, click ok and close out of this window and the Control Panel.
Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Verify the installed driver settings
Open the Windows Device Manager
Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
Verify no other devices are listed. If other devices are listed skip down to other devices section.
Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
Reboot the computer.
As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
My computer has sound problem
