Re: watch stops or loses time every time i wear it.
Normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
you can find an exper in the local shop where you buy the product and
they will give you specific service for your questions about your
product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
Every watch, both mechanical and quartz needs regular service.
When the oils in the watch dry out they get gummy and will work against the gear train. They also stop lubricating and friction builds up causing wear.
yes it can cause that but it could be otehr things too you have a lifetime warranty send it to skagen they will fix it at very low cost
http://www.skagen.com/service/orderWatchBandParts.fx
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second). Use your users manual to set the watch. By the way: Timex is one of the worst watch producers.
There can be hundereds of causes why your watch isn't working properly, so, I'll not name them.
One is clear- without help of skilled watchmaker your watch will NEVER work properly.
NOTE: It may sound very strange, but mechanical watches do NOT like to be left without job.
Next time you decide to leave mechanical watch aside for long time- do not forget to wind it up once in a 2-3 days even if you are not wearing it.
This will help to prolong watch movements life and keep timekeeping steady and accurate.
