I have a Bissell Cleanview 3596 and it is makes a load, deep roaring noise when I use it. This has been going on for a few months and it also seems to just move the dirt around. Yes, I have replaced the belt.
Sounds like the brush that the belt runs (or is supposed to run) is being kept from turning. If you can get the brush out to clean it and lubricate the ends that go into the holder clips, this should solve the problem.
With the new belts burning and smoking it appears that the motor is running okay, but as I said, the brush that is supposed to be turning is frozen solid from debris or dirt. Need to free the brush and lubricate the brush holders with some WD40.
If you are looking straight onto the vacuum it goes on the right side around a small metal bar and then around the brush. Make sure that when you push the brush up that both caps are twisted in the correct position so it will slide easily into the grooves.
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Sounds like maybe your motor went bad, part # 2031052. Would sell for about $60. When the bearings go bad, they can be real loud as well if the fan on the motor when it gets damaged.
