I would like to know how to unlock my blackberry 8900 cell phone by my self.
thanks
You can Unlock your Blackberry 8900 Curve with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry 8900 Curve Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry 8900 Imei Unlock Code .i hope this will help you :)
Good Luck.
Did you mean by using a phone jailbreak software? You can't unlock your phone in that way and you only need blackberry 8900 unlock code to unlock your phone by your hand. A reliable blackberry unlock code only can be obtained from your network provider or purchased at third parties sites.
Unlock your Blackberry phone for just $1.99! Cheapest and best solution on the Web!
http://www.globalunlockcodes.com
Hi all
To unlock a blackberry phone you must provide the IMEI and also the Mep code.
If you don't have, this is a small tutorial on how to get your BLACKBERRY imei & MEP
After that use the blackberry code calculator to generate the code.
Good luck.
