Though I am no longer using this TV with a Surround Sound system, I used to use an external home theater receiver with multiple HDMI inputs and several choices of outputs - including HDMI. I ran all the output devices (Roku box, Blu-Ray, HD DIgital Set Top Box w/DVR) in to the Receiver, then ran the HDMI output from the receiver to the TV. Connect your speakers to the Receiver as well, and you're all set - the TV is only receiving a video signal from the receiver, so you can even use the TV's firmware to disable the TV speakers. All the surround audio is handled by the Receiver, which becomes your giant "roundhouse" to use a railroad term. Simply turn on your TV, turn on your Receiver, and use that big remote to select your source - then sit back and enjoy.
If you hav e difficulty grasping what it is you need to do here, get back to me - we can exchange emails, and if you give me a list of your components, I will be happy to draw you a color-coded diagram showing you exactly how to hook this up for best results.
Hello!
Try to calm down! Yes, TV has bunch of inputs, but the only one you can use for a true "surround" in an optical or coaxial digital audio stream outputs. Accordingly, you must choose "dolbyG 2" input on your Home theater input selection. If that one has DVD or Blue Ray, HDMI delivers picture only to TV. For the same reason. If you have any analog sound inputs occupied at your TV, those might not work with streaming. Connect those to available analog inputs at home theater.
Good luck with project! I know you can make it!
thanks,
Alex.
Should be labeled, usually RCA type connectors, white, red and yellow....
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
