20 Most Recent RCA RT2350 System Questions & Answers
Coax vs. Optical cable
sadly, no :(
11/26/2013 12:18:10 PM • RCA RT2350... • Answered on Nov 26, 2013
No sound at all
Audio amplifier IC´s damaged need to replace it
11/19/2013 6:45:04 PM • RCA RT2350... • Answered on Nov 19, 2013
Unable to control volume to the receiver with my universal remote
There has to be another code for this then. Remotes have a way of manually programming them by going through all available codes known and not just the listed code that is supposed to work. I would follow the instructions for that method to find the proper code.
11/16/2012 4:16:31 AM • RCA RT2350... • Answered on Nov 16, 2012
Hi i'm trying to hook
Thinkin maybe check to see if there is an HDMI or S-Video option?
2/4/2012 8:08:57 AM • RCA RT2350... • Answered on Feb 04, 2012
0answers
0answers
2answers
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
1/2/2009 11:42:51 PM • RCA RT2350... • Answered on Jan 02, 2009
0answers
Overload Message
The amp probably shorted out from bad cable or yop probabaly you drove the amp into clipping and it blew out
6/7/2008 1:54:05 AM • RCA RT2350... • Answered on Jun 07, 2008
DTS
make sure your input signal is DTS.
1/14/2008 1:45:57 PM • RCA RT2350... • Answered on Jan 14, 2008
Rca 2600 home theatre
sounds like a component is getting hot. It probably needs to be looked at.
1/14/2008 1:45:00 PM • RCA RT2350... • Answered on Jan 14, 2008
How do i connect the pyle pslsw6 power amp to my av receiver, there are no rca jacks on the power amp.?
google Banana Plug to RCA Speaker Cable eBay $5.00 look at amazon amazon has 3 feet long cable. you can use RCA to bare wire cables and use binding posts on back of item.
2/21/2024 5:48:18 PM • RCA Audio... • Answered on Feb 21, 2024
3answers
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM • RCA Audio... • Answered on Jan 15, 2024
Looking for power supply for RCA RTD 317
The power supply is internal.
11/5/2023 8:35:31 AM • RCA Audio... • Answered on Nov 05, 2023
RCA Digital Voice Recorder RP 5120 won't unlock?
Question edited for clarity. The words 'want' and won't are interchangeable. Question moved from Cars and Trucks category. It appears to be a well known issue. https://www.google.com/search?q=RCA+Digital+Voice+Recorder+RP+5120+won%27t+unlock ..
9/29/2023 5:50:33 PM • RCA Audio... • Answered on Sep 29, 2023
RCA RT2350 System Logo
17 questions posted
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
unable control volume receiver universal
  • Audio Players & Recorders
