Fuji FinePix F470 Digital Camera Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The menu/ok and disp/back is not working
The buttons are not working...when you open it and says "date and time not set"...then click ok..its not working..please help me
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Feb 07, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201072
Points
38521
So...set the date and time and then press the ok button twice.
  • Hens Sep 10, 2013
    I have the same problem. Set Date screen comes up. You have to press Menu/OK first to set date and time (or Back to skip that). Neither button works. Nor does any other button. You don't seem to know the camera, you can't set the date unless pressing the OK button FIRST.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
787
Points
Camera goes on but,play button wont work.its not stuck or anything.
1helpful
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
1helpful
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
2helpful
Can I get rid of the date from my pictures?
To turn on or off the Date and Time stamp features, push the menu button. It's the small silver button on the back panel directly beneath the printed letter M, and just above the little green LED. This opens the menu. Now, press the right side of the ring shaped control button, where the little lightning arrow is. This will scroll through the different menu categories. Keep scrolling until you get to the one at the far right of the screen. It is a blue icon that looks like an envelope and a clock. This will bring up the menu for toggling the Date and Time stamp. Use the top and bottom of the ring to select the setting you want, and press the button in the middle of the ring, marked SET DISP, to select it. Then press the menu button again to get out of the menu and return to taking pictures.
3helpful
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
How to change date and time for Polaroid i531
Press the menu button, scroll sideways (press lightening icon) to Setup (tools icon), then down (disp) to highlight date and time. Press Set or the lightening icon to select the date and time setting, then press disp or the opposite upper part of the rocker to change the numbers, and the lightening or flower to move between the various date and time settings. Press Set when you are through.
If you leave the battery out of the camera for 48 hours, you will be invited to set the date and time at the next switch on.
You can download a manual for a similar camera, the i1036, at polaroid.com, but there does not seem to be a manual for this specific camera there. Try THIS LINK
Cant get in to my hotmail.comes up page not available
You may have a corrupt Hotmail page stored in your Tempory Internet Files folder. Clear this out and see if it loads then.....
START - PROGRAMS - ACCESSORIES - SYSTEM TOOLS - DISC CLEAN UP.
Post back if this works/doesn't work for you.
Found this solution and it worked for me by running all the way through:
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
3. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
4. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
5. Restart messenger and IE
I CANT GET THE DATE TO DISPLAY ON STYLUS 7010
there is a display button at the bottom right of the back of the camera. its the very bottom rocker buttons. it says DISP/? or/(and the trash symbol). knowing this go to look at your pictures (using the "play" symbol) and click DISP. the time and date should appear now.
22helpful
How do i change my date on my insignia digital camera
Press the Menu button, then select the Setup tab, then Simple Mode. Set Simple Mode to off, then select Date & Time. Set the time and date using the arrow keys, then press OK/DISP when you're done. Additional details can be found in the owner's manual.
2answers
Setting Time & Date
press and hold the menu/disp for or longer until the hq flashes. press the minus button until the time flashes...then press play button. press +/- until the hour is set, then press the ff button and change the minutes, then ff to the date and change accordingly. When finished press play then stop.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
