Did you try to do convergence thru the menu system?
no convergence, it before or just after focus menu
join this yahoo group and download this file from the file section
http://tv.groups.yahoo.com/group/Ws500/f...
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
If you mean FLASH FOCUS button, Yes but didn't help much.
I don't think this TV has any focus menu or convergence related option in menu. even the user guide talks only about FLASH FOCUS button for convergence. If you could point me to any other way to set convergence via menu then it would be a big help. btw, when I try to get in service menu (display, 5, vol-, power) then it shows "1" for #5 and #9. rest of the numbers are "0". Red light in front of the TV blinks 5 times. If this is indicating anything for diagnostics. Anyway Thanks for your help.
I have red arching lines across the screen, the screen is redish.
SAME THING AFTER A POWER ON THEN OFF NOW I SEE THREE OF EVERY THING IN RED GREEN AND BLUE LIKE IT IS OUT OF FOCUS
red color offset to the right especialy on the 2 sides. flash focus is worthless. anybody got an solution short of paying the repair man? thx
I am having the same problem everything looks 3-d and there is a arch in the picture at the top and bottom of the screen. All the colors look misaligned.
I also have a color convergance issue. I have purchased the parts now just need to know how to replace them. Anyone have access to free repair manual on a sony kp-51ws500?
I am having the same problem the green color is a arch
misaligned. And i try the system menu but i can't move the green color.
i had a problem with the green and red lines and was able to fix them , but now the picture seems to be out of focus,with green shadows and words that look to be in 3D please help me i need the most simple of terms i bought my tv used , thank you
