Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429 Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sears Kenmore Upright freezer is Making a loud humming sound
My Sears Kenmore upright freezer maintains the proper temperature, but it makes a high pitched humming sound. This sound sometimes goes away when I lower the temperature setting.
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Feb 06, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544886
Points
14368
Change the rubber washers on the compressor should work a treat...
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
1helpful
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 • Freezers
My upright freezer sound like its breathing
Call back the technician who installed the compressor.
Normal operation is mid position, not all the way up.
Got zanussi whirpool upright freezer afg8080/1x temperature gone to high is it worth getting repaired or buy a new one? freezer has been making a cliking noise and food is starting to defrost
if the freezer is over 5 years old,buy a new one under counter freezers not built in are fairly inexpensive and will cost less to run.fault sounds like temp sensor....
cheap part/labour intensive.....
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 • Freezers
2helpful
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
