SOURCE: Frigidaire Gallery gas range, oven door will not remain open
There may be a broken spring that helps the door stay open.
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
