20 Most Recent
Frigidaire FGF376 Gas Kitchen Range Questions & Answers
We have Frigidaire electric range ovan and we
You need to open the oven and look at the heating elements. Pull them out and check them with a ohm meter. That will tell you if the element is open or bad. i hope this was helpfull. Sawdust
Door lock
Set the oven to clean and et it go through the entire cleaning cycle again. Hopefully this time, the door will unlock.
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
JD YOU CAN SOLVE THIS PROBLEM ALL BY YOURSELF IF YOUR KINDA HANDY
WHAT YOU NEED TO DO IS GET THE MOD# AND SER# THEN GO TO THE APPLIANCE PARTS STORE OR GO ON LINE AND ORDER AN GLOW IGNITER OK GEORGE
Frigidaire lp gas oven
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'S NORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
How do I turn the volume down or turn off the beep from my Frigidaire Gallery 5.0 cu. ft. Gas Range when the oven reaches its intended temperature?
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
How to I adjust the flame in a Frigidaire gas oven.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
The oven and broiler elements are not working in my older Frigidaire stove. I suspect a blown fuse.
This is so confusing
You say
"The oven and broiler elements are not working"
Then you say
"Everything works except the burners'.
so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light?
Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange!
Click comment under my answer and also under Vince's and we will get you Fix-Ya.
