Pyle PIFMDK6 iPod Car Stereo FM Transmitter w/LCD Display Logo
Anonymous Posted on Jan 24, 2010
Iwave fm stereo transmitter
What does it do and how do I work it. This was a gift with no instructions
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Jan 24, 2010
Master
Level 3:
Answers
12061
Questions
0
Helped
4008291
Points
36390
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Testimonial: "Thank you so much-my granddad told me man was good for something-Inow know he didn't lie. LOL seriously I THANK YOU, the info was fast and informative"
Is there a bluetooth device that can plug into car stereo aux to play music from my iphone
Not sure about that but an FM transmitter can be obtained that will plug into your phone and not only received by your car radio but also any other FM radio or hifi you choose. Some of these also have bluetooth.
Some are a general use transmitter and the majority are for in-car use.
Amazon and ebay have pages of them at just about every price range.
Short range FM media transmitters are a much neglected and underrated solution to miles of connecting cables and poor performance - I have an FM transmitter usb dongle for my computer that allows me to listen to music files on a decent stereo as well as an Mp3 player/transmitter for the car...
Oct 19, 2020 • Cell Phones
tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 • Apple iPod touch
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
2answers
I JUST BOUGHT A iwave fm transmitter. UNFORTUNATELY I THREW AWAY THE INSTRUCTIONS, MY CAR STEREO PLAYS MP3 FILES,BUT DONOT HAVE A USB PORT, DO I NEED A STEREO THAT HAS A USB PORT, TO USE THIS TRANSMITTER
You don't need a usb port for mp3 playback, simply burn some mp3 files to a cd - not like an audio cd but a data cd (drag and, drop and burn the same way you would burn pitures to a disk) you will find that you can fit 5-10 whole albums on one disk.
Enjoy & good luck.
6helpful
I bought an iWave FM transmitter and it says to select the frequency 87.5 on my radio but I could not find this radio station it starts with 87.7 and could not make it play my mp3....how can I solve this?
There is no 87.5 on your radio so that frequency won't work -- you have to pick another frequency. Find an open frequency on the radio you want to transmit to. Then use the up/down buttons on the right to tune the iWave to the same frequency. That should do it. If you want to save that frequency on your iWave you press and hold the round button at the center bottom of the unit. The left/right arrow button on either side of the round button can be used to click through your saved frequencies. It's not very complicated, but it baffles me that they include no instructions whatsoever with this unit. Otherwise, it works pretty well.
I was given an iwave & charger for my car but it had no instructions so I don't know what station to put it on
You can select any station you want. On the 'on/off' button on the left side do a short press of that key to get the choice of frequencies. Find a good frequency with no interference (hard to do in a big town with a lot of stations). When you find one you like then press 'set' key and m1 (or m2 or m3) simultaneously to save that frequency. now you should be able to press the m1 key to get that saved frequency back.
How to hookup an IPOD to a pioneer avh-p6500 car stereo
If your car stero has a stereo audio input connector then you can plug a cable in the headphone on the IPod and the other end of the cable into the stereo audio input on the car stereo.
If you don't have an stereo input on the car stereo then you can buy a FM transmitter that is powered by the car's cigarette socket, connect the IPod to the transmitter, switch on the car radio and tune it to the FM station that matches the FM transmitter.
You can now listen to your IPod from the car radio.
Fm transmitter
I need to know wish to know on what raadio station I have to set up my radio so then I could connect my i-pod
3answers
Technika fm in car transmitter
Tune in the transmitter to one of your car wireless stations - switch on - play MP3 player and it should work
Hope it works
Tony
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
