I have a X2580 printer. It keeps saying "Align the Cartridges." What does that mean and how can I correct it? (I'm very new at all this and I really need all the help I can get). Thank you very much.
I have Lexmark X2500.WHEN I GIVE OPTION OF PRINT IT KEEPS SAYING ALIGN THE CATRIDGE.AND IT GIVE NO PRINT FOR THE REQUIRED DOCUMENT.WHAT SHOULD I DO?I have Lexmark X2500.WHEN I GIVE OPTION OF PRINT IT KEEPS SAYING ALIGN THE CATRIDGE.AND IT GIVE NO PRINT FOR THE REQUIRED DOCUMENT.WHAT SHOULD I DO?
You can't post conmments that contain an email address.
On my X2500 I had to print a special page and then scan it on the scanner and it somehow aligned. When the notice came up to print the alignment page I just had to click for it to print it and it walked me through the rest.
It might mean that your cartridge has become demagnetized. That happened to me and I had to replace the cartridge. The little brass covering at the front of the cartridge is very delicate and can become demagnetized if handled incorrectly. You can buy refurbished ones on line and they are not as expensive, but that is entirely up to you. Good luck.
First try to clean the gold contact points inside the printer, where the cartridge identification chip comes into the contact with the printer. this is located inside the cartrige slots. If that doesnt work check that the correct colours are being inserted into the correct slots. If you are using un-original cartridges or cartridges that have been refilled they may be incompatible or have been damaged through refilling, you must purchase original lexmark cartridges.
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
The cartridges compatible with the Lexmark X2580 printer are given below:
18C0190 - #2 color cartridge.
18C1530 - #3 black cartridge.
However, if you are a residence of USA or canada then you can call Lexmark technical support, so that they will replace the #2 and #3 cartridges for you free of cost.
you may call at 1-800-332-4120
hours of operation are given below:
Monday to Friday: 8 AM to 11 PM EST.
Saturday: 12 PM to 6 PM EST.
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
A simple question first - have you removed the protective tape from the bottom of the cartridges? What kind of printer is it? I suggest you unplug the printer for a few minutes and then try again. Are they the manufacturer's cartridges or a lower cost brand? If they are the latter, it's possible they won't work with your printer.
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
