The control panel part made by GE for my 1998 Kenmore wall oven has been discontinued. are there any places to find reconditioned parts for this oven or am I out of luck.
YES IN FACT THE FRONT PANEL DOES COME OFF,, JUST THE DISPLAY BOARD THOUGHT, that is where you can get to the switches,,, but sorry to tell you i cant even get the part i have 7 places i can get parts and all of them say it is discontinued,, thats not saying you cant find one it is just going to be a long and hard processe
Hello,Try this first! The control panel has a flat
ribbon cable that plugs into the relay module. The ribbon is actually
two ribbons pressed together. The plastic insulation has a defect, and
the leads between the two ribbons cross. You can separate them easily
by lifting them apart. Place a piece of paper between them to act as an
insulator. This should solve your problem. If that does not work, replace the defective parts yourself. You can do it for about 30% of
what a repair company would charge. it's either got to be 1. Control
panel 2. Relay panel. Thanks
GE is now fixing this problem, no charge. I called about mine, at 866-622-6184 They have the white version already available. A month wait on the black. Then they send out a service tech to install, free to you.
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
