How to change a start switch, and a lighted bottom element switch on a Bunn Omatic 3 station coffee maker (with a hot water spout on the side)
Unplug your brewer, take the 2 screws off of the lid, lift the lid, and you can see your switches from there.
Removal and Replacement for start switch;
1. Remove all wires from the switch terminals.
2. Compress the clips inside the hood and gently
push the switch through the opening.
3. Push the new switch into the opening and spread
the clips to hold the switch captive in the hood.
4. Refer to the List below When reconnecting the wires
BLU to Timer
WHI/ RED to On/ Left Switch
WHI/ RED to Liquid LevelControl Board
The warmer switch is replaced the same way, just make a note of which wire goes on which terminal when you take it off so you can replace them to the proper place. These switches are easily found at any local Bunn repair shop.
