An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
You will need to press and hold the clear or stop button for at least 3 seconds, if it is locked due to a cleaning function you will have to wait for it to cool down until it allows you to open it. You could do a hard reset and flip your circuit breaker for your kitchen off and then back on a moment later and try again.
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
