You can download this manual from UserGuidesDB.com they have the largest database of hard to find sewing manuals, can think of.Good Luck https://userguidesdb.com/request-manual-or-software-search/
Is the needle inserted correctly? It should not be difficult to change it. Here are some reasons for thread breaking. OLD thread, cheap thread, wrong thread for material and wrong needle size for material. Incorrect tension for material being sewn. Needle bent or too old. Hope this helps :-)
ebay might have what you are looking for. This is the first place I'd look for parts the stopped production. Reading material will always be in ebay than the manufacturer itself. Also try this one I found http://sewingwishlist.com/help/pfaff-1469-info.html
When you thread your bobbin and put it in the case the thread should be on the left side of that little arm on the bobbin case. It allows the thread to slide off that arm.
Another issue could be your lower tension. You may need to loosen or tighten it.
I had the same issue and the above two things eliminated the problem.
delta nm 902-05 instruction booklet
