Lexmark X5470 All-In-One InkJet Printer Logo
Posted on Feb 10, 2008
Lexmark X5470 scanner problem
Scanner says it is going to 'Download application list' then it displays 'Cannot download application list'. I am unable to scan anything.
The scanner has always worked, now I don't know why this has happened.
  • 7 more comments
  • mizann Feb 27, 2008
    just what you said my scaner tell me it's downing and then it say it's not
  • Anonymous Mar 07, 2008
    Yeah I have the same problem how do you fix it? It cannot scan anything.
  • ch1202 May 25, 2008
    Trying to scan photos but says "cannot retrieve application list" what do i need to do?
  • cds237 Aug 12, 2008
    Same problem here . . . Straight out of the box printer is working perfectly, but when I push the Scan Mode button the screen says "Downloading Application List" for about 30 seconds and then "Cannot retrieve Application List" start flashing across the screen. Have the same problem with a Lexmark 5495!
  • Anonymous Aug 18, 2008
    I NEED A SOLUTION! PLEEEEASE HELP, SAME PROBLEM! I installed the drievers again, and even re installed it. Please help me!
  • almark8888 Sep 17, 2008
    I just bought a Lexmark X5495 and got prompted for a "wiafbdrv.dll" file (so I googled and found a copy of that file), now, it gets up to the "plug your USB cable in prompt, and when I do and click to go on, the computer freezes.
    Please help
  • Anonymous Nov 09, 2008
    same problem as mentioned above
  • Anonymous Feb 12, 2009
    This is a POS!
    customer service has no clue
  • Anonymous Mar 08, 2009
    i used a disc to add my all in one, but i was previously useing a gateway.
    now i'm useing a compaq presario....printer works well on windows xp
    and printing pictures from the computer, but unable to scan on personnal docs.....wont pickup on setup list for scan process
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3088
Points
5
I had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Anonymous
Level 1:
New Friend:
  • Posted on Oct 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3088
Points
Je n'arrive pas a scanner mes documents
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
42139
Points
34
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
849
Anonymous
Level 1:
  • Posted on Feb 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3088
Points
I have the same problem. I cannot scan in WiFi to this laptop but can with the USB cable. Even with the USB cable it says that it is downloading the application list and the "cannot retrieve application list."
I have Paperport Pro 11 software for scanning. I am able to use the interface with the USB.
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Mar 03, 2009
SOURCE: lexmark x5470
937
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
2helpful
Lexmark x3350-4500 scanner doesn't work
Please follow the steps given below to update the scanner driver:
1. Right click on My Computer and select Properties.
2 Click the Hardware tab and select Device Manager
3. Right click on the scanner entry that is displaying a conflict.
4. Select Update Driver from the drop-down menu that appears. The Hardware Update Wizard appears.
5. Select Install from a list or specific location, then click Next.
6. Select the Don't search... option and then click Next.
7. Click Have Disk. The Install from Disk dialog appears.
8. Click Browse and select the Lexmark CD from the Look in drop-down list.
9. Double-click on Drivers.
10.Double-click click on Scan, select the lxbksxp file, and then click Open.
11.Click OK. The following screen appears:
12.Click Next to start the scanner installation.
13.When the installation is complete, click Finish to close the wizard.
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Lexmark 5400 series
hmmm..what are you using for the scanner function?
http://tinyurl.com/6qcpgy
2helpful
Scanner
this happened to me yesterday after recieving whatever lexmark update my computer downloaded. I restarted everything, computer and turned on/off fax and unplugged for a bit.
It seems to be working OK now.
I know that's lame dell-style, advice, but the restart worked for me.
Scanner problem
try to reinstall the print management software, first.
got backup?
2answers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
