It turns off and lamplight flashes. It makes noise as if rebooting....but nothing happens.Audio works but the video.
We need to have in mind this TV uses a UHP lamp that are design to last you (PHILLIPS LAMP)6000 TO 8000 LAMP hours and is you have a generic lamp it could last you 3500 to 4500 lamps hours so please have that in mind and if you just replace the lamp and you are still getting the problem then it could be you ballast witch is the small circuit board in charge of sending the correct amount of current to your lamp and if that faulty it will make that symptoms the you have also you can go to www.fixyourdlp.com for more info on this problems
Regards
