20 Most Recent
Kenwood KAC-9152D Car Audio Amplifier Questions & Answers
What is the p. con on the back of the kenwood
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
10/8/2017 4:08:55 PM •
Kenwood...
Answered
on Oct 08, 2017
Amp has power, turns on with stereo, but sub isnt
if you have a protection light that is on it means the amp is in protection mode and wont allow any power to the sub this usually happens when the sub or wiring shorts out or if there is an internal failure in the amp or if its overheating. check the wires and connections and test your sub on another amp.
5/13/2014 12:36:45 AM •
Kenwood...
Answered
on May 13, 2014
I have a KAC 9152d with a red light on.
your ampifier is in protect mode, try to dettache the speaker and turn on it.if the green ligh on ,one of your speaker is deffective but still the red light on theres something wrong with your amp.
4/13/2014 11:57:50 PM •
Kenwood...
Answered
on Apr 13, 2014
WIRE DIAGRAM FOR HOME SECURITY CAMERA
the diagram is supplied with the camera. if not, find the connectors that the camera uses to send the tv signal.find the model number of camera and setup the power connections and route the signal cable to your tv or server or recorder.setup the power cable and connect it to your power source. provide more information about your setup.
11/15/2013 4:34:15 AM •
Kenwood...
Answered
on Nov 15, 2013
Kenwood repair manual
I have the Kenwood KAC-9152D Repair Owners Manual. This is my E-Mail address.
[email protected] send my a e-mail. & I will e-mail back 2 U w/the Manual ATTACHED
12/21/2011 12:47:08 PM •
Kenwood...
Answered
on Dec 21, 2011
I have a kenwood kac-9152d
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
9/26/2011 4:17:44 AM •
Kenwood...
Answered
on Sep 26, 2011
