How can I add more handsets to uniden base phone
SOURCE: uniden powermax 5.8 handset
place both handsets on the recievers for 24 hours so they can register to there spots
SOURCE: how to set up uniden phone to base
If the handset has previously worked with the base - press the hangup button and the # key at the same time on the handset for five seconds and follow the prompts to deregister the handset. (System reset - deregister HS - which handset) It will tell you that the handset is deregistered. Then put the handset onto the base and it will register the handset.
SOURCE: Add extra handsets to Uniden 5.8Mhz
first thing to try.... place each handset into the base of the system you want them to be on.... and watch the charging light... it should flicker... the phone may work then... do that with all the phones..... also what is the make and model of the unit you already had.
And if you don't already have it... here is the user guide for that phone system.
http://www.uniden.com.au/resources_main/pdfs/DSS7855_7855+1_OM%20.pdf
SOURCE: How do I record a new message please?
There should be a button that reads "greeting".If there is no button that says "record" or "rec",then just hold down the greeting button and it should prompt you to record.It seems odd though,the digital answering machines usually hold their greeting even when losing power and coming back on.If it currently gives a "computer voice" greeting it should not be a problem.If there is no "computer" greeting,there may be a problem.Good luck.
Testimonial: "Thank you for your help and speedy reponse. I will try to set it up when I get home tonight"
SOURCE: Hello, I have a Uniden
I have a Power max 5.8ghz and need to know how to change the number of rings before I pick up.
I don't see any set up button
