20 Most Recent Uniden D16602 Twin Cordless Phone Questions & Answers
2answers
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
12/4/2023 7:59:49 AM • Uniden D16602... • Answered on Dec 04, 2023
2answers
How do i add another
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
4/30/2023 9:27:35 PM • Uniden D16602... • Answered on Apr 30, 2023
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica, I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here. Uniden Technical Support 1.800.297.1023 M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=& 1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time. 2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem. 3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about. I hope that helps. Good Luck!
1/8/2014 7:50:07 PM • Uniden D16602... • Answered on Jan 08, 2014
Uniden D1660-2 how to set up voicemail and message
The Uniden D1660-2 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you subscribe to a voicemail system offered by your phone company, please contact them for instructions on accessing their voicemail system.If you need a D1660-2 manual, you may download a copy here.
3/14/2012 4:27:38 PM • Uniden D16602... • Answered on Mar 14, 2012
Need loudest ringtone possible
To increase the ring volume, press the up-arrow button.You can also change the ring tone using the Ringer Tones option in the setup menu.If you need a manual, you may download a copy here.
3/4/2012 8:58:08 PM • Uniden D16602... • Answered on Mar 04, 2012
How to take phone off silent mode
Press and hold # on any handset.You can download the manual here.
10/6/2011 9:11:27 PM • Uniden D16602... • Answered on Oct 06, 2011
How do I change my voicemail password
The D1660 doesn't record voicemail. If you subscribe to a voicemail system offered by your phone company, contact them for information.
9/19/2011 9:32:11 PM • Uniden D16602... • Answered on Sep 19, 2011
How to change the ringer tune on a uniden d1660
You can download a copy of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660om.pdf
The ringer tone is in the "Handset Setup" menu (page 6). You can also assign a personal ring to each person in your phonebook (also on page 6).
9/12/2011 7:28:24 PM • Uniden D16602... • Answered on Sep 12, 2011
Lost the handbook for a
9/4/2011 12:19:36 AM • Uniden D16602... • Answered on Sep 04, 2011
[email protected]'t turn off silent mode
Press and hold # on any handset. At the prompt select "Always on."
The silent mode description begins on page 9 of the manual at
8/25/2011 6:37:13 PM • Uniden D16602... • Answered on Aug 25, 2011
How do i get the phone off silent mode
Press and hold #.
Silent mode begins on page 9 of the manual at
8/25/2011 6:35:33 PM • Uniden D16602... • Answered on Aug 25, 2011
NEED TO SEE USER MANUAL
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI4288-2om.pdf
8/24/2011 6:02:45 PM • Uniden D16602... • Answered on Aug 24, 2011
4answers
I use twin Uniden DECT6.0 handsets, and on both,
Press the END button to exit or erase the message. Press Menu/Select. Scroll up or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
8/8/2011 2:52:35 AM • Uniden D16602... • Answered on Aug 08, 2011
I have a 88 message on my uniden power max 5.8, model tru9480-3. can i get rid of that if the base is not in service.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time. With.the.phone.in.standby, .press.[ ].to. delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are. permanently.deleted. https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual ..
12/29/2023 1:04:31 AM • Uniden Lands... • Answered on Dec 29, 2023
I have a UNIDEN AS 8116-2 phone, I have lost the user manual. I need to know how to change handset 2 to handset 1 for UNIDEN AS 8116 phone
Uniden Support - Downloads and Manuals
uniden.info https://www.uniden.info > download Uniden Support - Downloads and Manuals. Missing: 8116-2 ‎' Must include: 8116-2
6/16/2023 4:25:25 AM • Uniden Lands... • Answered on Jun 16, 2023
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 . I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes. Cindy Wells
5/2/2023 9:42:31 PM • Uniden Lands... • Answered on May 02, 2023
Uniden D16602 Twin Cordless Phone Logo
29 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
intercom not work
  • Lands Phones
