Oven doesnt heat, after a few minutes displays error code F3 E2
When attempting to heat my whirlpool accubake the electric element does not warm up--I have checked the contacts and they seem to be ok. after a few minutes it beeps and shows on the display F3 E2. Any ideas what this means and how I can fix it?
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board. If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe. If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing. I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information. RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell. In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^!
F3 E2
9
At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
