Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: i am trying to download pic, communication error on camera
Not knowing your computer OS hard to say. Try re-installing the camera software.
SOURCE: Communication Error
try either a card reader (rather than connecting your camera to the computer) or try erasing photos. it seems that it happend when the card is too full. i had the problem and had to go under 3000 photos and then it worked.
hope this helps.
SOURCE: COMMUNICATION ERROR: Trying to download my 3,500 pictures from my
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
SOURCE: "Communication Error"
