Gently tap the hard drive with an opened hand and see if you can get it to spin up one last time.
click start control panel administrative tools computer management disk management if you can see your drive right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Some addition links found on Google
http://www.datarecoveryreview.net/
Of course it can be sent to a data recovey company if you really have to get the data off.
hope this helps
