The display /control facia panel has cracked and distorted on my SGS43Eo2 dishwasher. It is possible for me to purchase a replacement panel from Bosch, but how do I remove the old panel from the machine and fit the new one?
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
exactly the same as above - I have ordered a replacement fascia but have no idea how to remove and replace. I have tried undoing the screws around the rim of the door edge but no sign of how to remove the fascia afterwards.
all advice appreciated. Does anyone know where I can obtain a service manual? I have tried Bosch but they just want to steer us to using an expensive service engineer.
thanks
