Not knowing the make or if the machine is logic controlled, it’s very hard to diagnose. If it’s a logic controlled machine, my guess is the board is bad.
I have a Bosch that was stuck in pump down mode even when the door was open. The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float. I had recently cleaned the incoming water filter and must have loosened the water line tube.
I agree with you, I cannot see how any repair to a Bosch diswaher would justify or require it to leave your site let alone going to a repair shop. These (as any other manufacturer) are designed to be serviced in the home. To address the problem I would need more detail and clarification. Is the issue that the drain pump runs constant ? Does the tub get drained of water ? Let me know as much as you can and I should be able to assist you...depending on your mechanical abilities/comprehension. Please verify the model is indeed a Bosch SHV46C03. Thank you.
Open up the filter and clean the filter out but also check the filter well.
Our bosch DW has a 2nd filter inside that.
Also check the filter is not broken.
Please dont forget to vote this answer was helpful
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
Here is the link to the installation manual;
http://www.bshextranet.com/files/techtoolbox/SHV46C13-SHX43Cii.pdf
pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached.
Hope this helps :)
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
