I have a Wilton 15'' drill press with the 7/8'' spindle. The problem is the chuck and bit keep falling out. Is something worn or is there a part I'm missing. I bought this used and don't know much aboout them. The guy I bought it from said you just push it into place and whack it with a rubber hammer.
There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
