Most likely you have had an lcd panel failure. The only way to tell for sure is either hook the laptop up to a tv or an external monitor, if the video chip is good it will send the signal to the external monitor and you can run the computer that way. If you do get a signal on the external, then you need to change out the lcd panel. As far as the dvd, you probably just cannot see that everything is working because the panel has failed.
