Have two remote both are working intermittently the one button on both rarely opens the doors now and when both buttons are pressed nothing happens or I have to open the front door and stick the remote out to get it to work
2 steps for you... first put new batteries in the remote. next trip the door mechanism by pulling on the rope. that frees the door from the chain that operates it. then close and open the door manually to prove the track is ok. then close the door and reengage the tripped mechanism. now press the button on the remote to retry. BTW... most doors will reset the catch mechanism automatically. just press the button and let her go.
The correct way to program a remote is to hold the button down on the remote and then press and immediately release the learn button. If this doesn't work your logic board is bad.
yes, the remote has a function that if the unlock button is held down the windows and sunroof will open automatically. Perhaps you have a remote that intermittently sticks causing this concern.
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
new model pacific 1002mk2 (ASDA) using remote.; press open on remote press clear press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display! The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03. Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only: 1. Press 'open/close' button (the draw should be left open). 2. Press the 'clear' button. 3. Press '1'. 4. Press '3'. 5. Press '6'. 6 Press '9'. 7. Press '0' (zero for multi-region). 8. Press 'open/close' button. End.
or
1. switch on dvd with remote (leave drawer closed) 2. Press: setup 3. press: 7 (note nothing will happen) 4. press: pause/setup button (again nothing will happen) 5. press: previous/I<< button (nothing will happen) 6. press: Next/>>I button (nothing will happen) 7. press: setup
