20 Most Recent
Viper RCVGC022 Remote Control Questions & Answers
I have a 94 grand prix with a dei remote start not
It sounds like there's no power going to the starter wire. Try and locate the brain under the dash for the remote start. It should be black and about twice the size of a deck of cards with a few harnesses hanging out of it. Usually it is zip-tied to a wire harness or bracket to keep it secure and from falling down onto your feet. There should be several wires much larger than the others, and you should see fuseholders on the 2 red ones. Usually one of the fuses is used solely for the starter. Check both fuses on these larger wires. Should be 30 amp green ones if I remember right. Also, while you have the brain accessible, write down the model number on the brain itself to help you in the future. Most DEI remotes can be used for almost any DEI/Viper/Your Valet system, so it's really hard to tell what you have just by looking at the remote. If the fuses are fine, you may need to take it to a shop (anyone that sells Viper and such). If you have a chip in your ignition key, it may also be the security bypass module that gets installed with the remote start. You will only have this bypass module if you have the little chip in your ignition key. Hope this helps, good luck.
Chad
I can not start the
check first your remote control if it is sending a command once you press a button, use the camera of your cellphone to check whether the infra red light is emitting a signal once a button is press .to do it
open the camera and aim it on the remote sensor press a button and you should see the sensor is lit.if not then you need to open the cover of your remote and try to resolder the terminal of the sensor.try to clean also the remote reciever of the viper..let me know if this work...or post a comment if you need further assistance.
Viper remote starter-
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Directed Electronics (Viper) Car Security System
First of all did you remove a connection from the battery in your car so that the system can reset?
Try that first and at the same time take the batteries out of the remotes for a minute or so and hook back up.
